Old 12th May 2014, 01:03 PM
Default seat supports
Gent's can i have some help. Does anyone have the positions of the seat supports for the seat runners to bolt onto so i can weld them to the chassis before i paint my chassis
Old 12th May 2014, 01:05 PM
MikeB MikeB is offline
Hi Matt,
This will depend on what seats and runner you use, so there's no standard pattern. I think most builders get there seats and make the mounts to fit.
Mike
Old 12th May 2014, 06:27 PM
Originally Posted by MikeB View Post
Hi Matt,
Mike
yep each will be different
Old 13th May 2014, 08:10 AM
Some of the Renault MPV 's have detachable seats in the rear and the subframes could be used or even the seats as they are fairly small but still usable.
Old 13th May 2014, 12:23 PM
rpjg1975 rpjg1975 is offline
My mate has just fitted the rear centre seat from a Peugeot 307sw in his mev exocet. Decent looking seat and narrow enough for roadsters too by the looks of it
Old 20th May 2014, 01:00 PM
Oscar Oscar is offline
I've already changed my seat mounts 3 times
Keep changing my mind/finding better setups!
Photos of the project so far:
Old 20th May 2014, 10:39 PM
Badger Badger is offline
Personally I'd be tempted to leave the seat mounts until quite late in the build - just clean off the paint around the area you need the mounts when you want to fit them. The problem is (as MikeB mentioned) that there is no standard fitment, so it'll depend on what you get.
Your alternative is to get your seats now and make an educated guess at your driving position (easier if you have the column). This also allows you to make "Brrrm brrrrm" noises and pretend to drive it. Not that I've ever done that mind
