Old 13th September 2013, 11:04 PM
Default Build has now started
Hi guys
I have finally started my build so here goes the next 3 ish years!!!!
I think I have done the photo bucket correctly aswell.
So first question with the welds on the Sva how do they like to see them ground down or left??????
http://s830.photobucket.com/user/bro...brary/Roadster
Build pictures
Old 14th September 2013, 12:48 AM
I've never heard about IVA examiners paying any attention to the welds, except the ones for the seat belt anchor points. The accepted wisdom on here is to flatten the welds where ali or GRP panels will sit and leave the rest as they are.
Old 14th September 2013, 07:10 AM
As I general rule I only 'reduce' the welds where the panels will touch them. Do not grind the weld completely flush with the surface of the tube leave it about 0.5mm proud otherwise you might just have not bothered to weld it. If your going to be using stickaflex to bond your body panels on you should end up with a layer 0.5-1mm thick any way so the reduced welds should not cause a problem.
Old 16th September 2013, 10:34 PM
Smile
After having a productive Sunday it's starting to look something!!!
Through out my build if anyone sees something that doesn't look right please comment all advise would be appreciated!!!
Build pictures
Old 16th September 2013, 10:48 PM
These things just fall together over a few weekends just add some welding sparks and your away.
Old 17th September 2013, 08:31 AM
Looks like a cracking start good luck with your build
Old 13th February 2014, 10:17 PM
Talking
Not done an update for a while but I'm still building and will update the photos very soon once I'm out of the garage!! So the chassis is complete now making the wishbones, so far I have not brought anything other then the metal to make the parts. Progress has been a little slow but I have rebuilt my mates vxr after he blew it up and the gearbox plus moving soon so packing boxes! Good to see all the progress on your cars and I must say I do keep looking at the forum for advice with certain bits!! Must go parts to source and buy flebay is my next best friend for cutting discs.
Build pictures
Old 14th February 2014, 07:46 PM
Talking
Uploaded some new photos
Build pictures
Old 14th February 2014, 08:47 PM
ba gum lad that teks me back a bit lathes are bluddy handy to have around, at least you aint got any mushies to turn up
Old 15th February 2014, 01:52 PM
They certainly are just bloody expensive but the money it saves in the long run and just having it to hand!!
Build pictures
