Old 9th May 2010, 02:20 PM
Question Suspension bolt kit group buy
I will soon be ready to bolt all of my suspension back on, for the last time
Although I have plenty of bolts, unfortunately, they are set bolts & I personaly, don't think it too wise to use them !!
Most of you will be aware, if fixings are bought in larger quantitys, it tends to work out a lot cheaper
Have gauged some prices & here's what I have come up with.
Full suspension & diff mounting Kit
2, M12 X 260mm bolts ( Rear uprights )
2, M12 X 200mm bolts ( Diff mounts )
20, M12 X 75mm bolts ( Wishbones, rear camber adjusters & Lower rear shock mounts )
6, M12 X 60mm bolts ( Front shocks & rear upper shocks )
30 M12 Nyloc nuts, Type p, 14mm thick
60 M12 Flat washers ( One for each side of the bolt ) Form A 24mm od, 2.5mm thick
60 M12 Black plastic nut covers
I have costed each kit at about £22.50 - £25 Max, dependent on postage cost.
To make full use of buying full boxes of the longer bolts ( This is where the bulk of the cost is ), I will need to find enough interest to shift 10 sets .
I am quite happy to organise a group buy as it may help others avoid the headache of finding the long bolts & paying through the nose by buying small quantitys
Any thoughts welcome.
Edit
Just to add, the bolts will be High Tensile 8.8 grade & all bolts, nuts & washers will be Bright Zinc Plated
2nd Edit
Here's the list so far
1: Bonzo + nut covers
2: Tatey + nut covers + Plain nut set
3: Greasemonkey + nut covers
4: KenK + nut covers + Plain nut set
5: les g + nut covers
6: HandyAndy + nut covers
7: CarlKnight1982 + nut covers
8: David 17
9: Luke2482 + nut covers
10: Ginger Nutter + nut covers
11: Geeman + nut covers
12: Tkpm + nut covers + Plain nut set
13: onedayTM + nut covers + Plain nut set
14: Ozzy1
15: Hoybi
If any of you are confused about the nut covers, please read further down the thread.
I have found a cheaper source for most of the fixings in addition to a low cost source of M12 plastic nut covers .... Looks as if I can include nut covers without increasing the kit price
Old 9th May 2010, 02:38 PM
Tatey's Avatar
Tatey Tatey is offline
Count me in Bonzo!
Old 9th May 2010, 02:51 PM
Hi Tatey
I think the best thing to do is start a list of folk that are interested
If anyone thinks the quantity or any of the sizes are wrong let me know .... It can be ammended accordingly & should not affect the price.
If you want in, just add your name to the list
1: Bonzo
2: Tatey
3: Greasemonkey
Old 9th May 2010, 03:29 PM
greasemonkey greasemonkey is offline
me to please
Rome wasn't built in a day!!
http://www.flickr.com/photos/3667569...17844956/show/
Old 9th May 2010, 03:49 PM
Originally Posted by greasemonkey View Post
me to please
Added to list
Prices are based on the lowest price that I can find at the moment
Rest assured, i'll continue hunting & will get to my local wholesaler to see if I can get a better price break.
Determined to get the cost down, as low as possible
Old 9th May 2010, 04:46 PM
KenK KenK is offline
Me too please, thanks
1: Bonzo
2: Tatey
3: Greasemonkey
4: KenK
Old 9th May 2010, 05:00 PM
Nice one KenK
I think One more & I will go ahead & order up .... I can then leave this offer open untill all 10 sets are gone
Now the good news
I have found a cheaper source for all of the fastenings except the longest bolts.
This stockist also has the Plastic nut covers at a very good price ( Some required fro IVA puposes )
Would folk like the appropiate nut covers included or would you prefer a lower, kit price ?
It would also be great if someone has an idea of exactly what nuts need to be covered .... It would be a real pitty not to order enogh if that's what folk want
Old 9th May 2010, 05:22 PM
Tatey's Avatar
Id prefer for the nut covers to be included please Bonzo. I'll need them eventually and I can't see it costing much extra.
I know for certain that the roll bar bolts need to be covered (however i wont be needing these as my roll cage will be fully welded in).
Old 9th May 2010, 05:24 PM
les g les g is offline
1: Bonzo
2: Tatey
3: Greasemonkey
4: KenK
5: les g & the nut covers please
Old 9th May 2010, 05:29 PM
You are dead right there Tatey, some nut covers will be needed for IVA
Being as I have managed to find a lower cost source for most of the fixings, i'll be able to include nut covers without increasing the original estimated cost of the bolt kit ( If that's what folk prefer )
I'll have a study of some post IVA buid pics & see if I can work out what nuts need to be covered
