Old 18th November 2010, 08:48 AM
Question Oil pump priming
I've just filled the engine with oil & thought it would be best to circulate some of it through the system seeing as it hasn't had any in for about 8 months now.
In total I must have cranked the engine for 5 minutes, and still have not got any oil showing at the filter.
When I altered the pickup & sump I cut 25mm from each part. Have about 3-5mm of clearance between the pickup & bottom of the sump.
I've tried squirting oil in through the pressure relief valve, oil filter ports, still nothing.
What have others done? Would you just fill the filter & start the engine and see if oil light goes out?
Pain having to split engine & box again to get to the rearmost sump bolts.
Old 18th November 2010, 12:17 PM
mark mark is offline
Does the oil pressure warning light go out?
All i have done for a first start is disconnect coil pack and fuel and turned over until the light went out then reconnected fuel and spark and fired it up
Old 18th November 2010, 01:15 PM
Haven't got the wiring sorted yet. Just connecting starter straight to battery. Even with oil filter off when cranking no oil comes out, so I wouldn't expect the light to go out.
Old 18th November 2010, 05:15 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Dave,
not critising your welding but you did make sure there was no leaks from your pick-up before fitting it?
ie - blank it thenfill it with white spirit and see if it seeps through?
Its alot easier to suck air than cold oil!!
Probably doesn't help at this stage.
Daz...
Old 18th November 2010, 07:46 PM
Perhaps the pump is not airtight and cannot suck the oil in? Perhaps it's worth feeding some oil into the pump through the filter hole?
Old 18th November 2010, 08:13 PM
If it is towable take the plugs out and tow it,rig up a bulb to the oil pressure switch.
All you need is a live to live feed to bulb and the other to the switch as the rise in oil pressure breaks the earth and puts the light out.
Old 18th November 2010, 10:08 PM
Thanks for all suggestions. I've decided the only way to know for sure is to take the sump off and check everything again. I can then have a proper go at priming the pump directly into the pickup port. Failing all else it will be a new oil pump just to be sure.
Old 19th November 2010, 12:31 PM
The pump should be self priming unless very worn.
Old 19th November 2010, 05:20 PM
snapper snapper is offline
I take the top off the pump and pack with vasaline.
Then take out the distributor and spin up the pump drive with a battery drill
Pinto
This gives flow and pressure without wrecking the bearings
Old 19th November 2010, 05:37 PM
Going to try taking the plug out above the pressure relief valve tonight, and pump engine oil directly into the pump while turning it over with a ratchet. If it has got 'dry' that should sort that problem. I have also got a adapter made up to put a 1/2" socket into my power drill. That should hopefully spin the engine over quick enough to see if it builds any pressure.
Failing that sump off to see what is going on.
