Old 30th December 2010, 08:07 PM
wazac wazac is offline
Default cosworth t5 gearbox and 2.0 duratec
Hi after some info reguards engine and gearbox fitment,i have ordered a flat pack chassis from HandyAndy and have been looking what to fit,i have sat in my garage a cosworth t5 gearbox been sat about 10 years,and i am in the process of taking a 2.0 duratec out of my brothers fiesta st to put a 2.3 turbo mazda mps duratec engine in,do i need a special bellhousing or am i better doing 2.0 zetec with type 9 any help please thanks
Old 30th December 2010, 08:42 PM
A Cosworth T5 gearbox will need a special bellhousing to get it to a Duratec engine. These can be picked up from the US (Quad4Rods) for around £400 (inc shipping and tax). Although RWD motorsport make one for £200 to go from a Duratec to Type 9 or T5 to Zetec? You'd have to ring them to see if they make a hybrid one. Hope this helps.
Old 31st December 2010, 08:24 AM
snapper snapper is offline
The T5 box has the best ratios you could hope for on a standard Ford box, the Duratec is a fantastic engine and can make 240 bhp with a set of cams and throttle bodies, I would definatelly build my car around this combination of parts, you won't regret it.
Old 31st December 2010, 09:50 AM
Wazac......... if you need the tranny tunnel steel (where the bellhousing end is ) supplied over long to allow you to accomodate your choice of gearbox then just let me know, as that way you,ll be able to fabricate the tunnel/bellhousing area to suit .......just keep in mind the pedal box dimensions , happy to "work with you" to create what you need on the chassis front
