Old 4th May 2011, 06:29 PM
Default Fuel Tank Sender / Instrument Gauge
Following my walk around and chatting with various people at Stoneleigh this year, it flagged up a few small items I need to resolve.
The fuel tank requires a seperate earth via the sender unit nuts, so should the fuel fuel gauge alway show a reading while the battery is connected, or only when the ignition switch is on?
Old 4th May 2011, 08:53 PM
Mine only shows when the ignition is on, this is with a premier loom.
Adrian
My Build Pictures:
Old 5th May 2011, 10:57 AM
Hi Nick ( good to see you at Stoneleigh ).
My fuel sender is earthed from the sender unit into the main earthing system within the loom, it shows the fuel level when ignition is off, tho I,ll be honest, my system might also be confusing itself ( electrics confuse me ) as I also have a battery isolator switch which when turned off still shows the same level on the fuel gauge.
I,m not sure if its needed but I also have my fuel filler cap/aerostyle cap earthed direct to the chassis too.
Old 5th May 2011, 04:48 PM
some gauges go to zero when power is off, on some the needle stays in its last position. it is a function of gauge design, not how it is wired.
Old 5th May 2011, 08:11 PM
Phew...
Thanks for that, I must admit I thought I,d made a boo boo with the wiring, me & electrickery don,t get on
I also thought it might be due to not having filled it full yet ( price of fuel to just sit in the garage...nooooo )
Old 8th May 2011, 12:10 PM
tex tex is offline
ideally if you an you dont want the guage showing fuel is full or lots in when you walk away from your car for security purposes.. gives TWOCers a hint that they can get far..
Old 8th May 2011, 07:30 PM
carlknight1982's Avatar
Hey Handy, think of it this way, the price of fuel at the pump isnt going down, youd save filling it up now :P
Roadster No 2 build
Cost to Date : £93
