Old 10th March 2012, 04:41 PM
Default Megajolt
I have just been offered a used Megajolt, leads etc thats been taken off a 4 cylinder Sierra (Pinto engine) , not knowing much about Megajolts, does anyone know if I can use it on my V6 Engine? If so what is is worth second hand?
Old 11th March 2012, 06:29 PM
is it just the mega jolt?
It should be compatible with any engine if set up right with the correct MAP.
Using an EDIS 6?
Old 12th March 2012, 11:49 AM
brainbug007's Avatar
I would agree with cyberbeej, all you should need is an edis 6 and to update the map for your engine. Although really isn't the megajolt only really good for bike carb conversions and won't that be quite tricky with a v6 as you'd need to split the carbs etc to make 2 banks of 3?
Old 12th March 2012, 06:49 PM
That makes it even worse as I am Manual fuel injection.. Think I will give it a miss
Old 13th March 2012, 07:21 AM
snapper snapper is offline
Megajolt will work with any fuel system as it only replaces the distributor.
If you are running mechanicals fuel injection you can leave that on and use Megajolt for spark.
I found it pretty easy, as for mapping you can start with a linear 2d map that copies the distributor then modify into a 3d map.
The benefit for me is that I can run a wild cam on the engine but have easy starting and a smooth idle at lower revs than with a dizzy, fuel economy when cruising is also improved.
Old 17th March 2012, 07:18 PM
MEGAJOLT LITE JR V4 PROGRAMMABLE IGNITION
Due to the large number of enquiries for this unit from various sources, the fairest way is to but if for offers on Ebay.
http://www.ebay.co.uk/itm/2209789832...84.m1555.l2649
