|  GRP side panels / 'H' tube alignment - good enough? A question for everyone who has fitted their GRP sides. Would you go with panel alignement that was as good (or bad) as what is shown below? Essentially - where the panels bend inwards, i.e. where the dashboard side of the scuttle sits - is sitting about 5mm forward of where the chassis rails have the same bend. I don't have The Book to hand, but think it's called tube 'H'. Offside  Nearside
				__________________ http://meandthekitcar.wordpress.com/ |
|   Think I would of tried to nudge it back a little.  But 5mm is nothing. Esepecially with fibreglass.
				__________________ http://www.facebook.com/EquinoxProducts http://www.haynes.co.uk/forums/showthread.php?t=13110 - Z20LET into a Roadster http://s775.photobucket.com/user/ben...?sort=6&page=1 |
|   Thanks Ben - helps to get others perspective. I reckon I may be able to get marginally closer, perhaps another couple of mm. Btw- what did you do about the join between your side panels and the rear panel?
|   My join is right by roll cage above wing. If you get a right tight fit, couple of coloured rivets to keep all in place you don’t really notice it. I was lucky and have ball bodywork so used a tiny bit of black silicon to cover joint. Bit like you see on other vehicles.
