Old 9th November 2009, 06:13 PM
Default rear uprights with disks
I'm making some rear uprights to suit the disk set up but can't remember what side the caliper goes on (parts where removed over 5 years ago) I don't think it makes a difference but as there not mine I'd rather check first.
Old 9th November 2009, 07:30 PM
Ricky Ricky is offline
hi can someone please help me with some info i just wanted to find out about part RU7 does it fit flush with the top of the steel pipe and does its get welded onto the steel pipe with the lines in line with the holes part RU8 so could anyone help me please
Old 9th November 2009, 09:37 PM
I ground a 5mm weld prep around the outside edge of RU7 welded it completly, ground it flush then welded RU8 to both RU7 and the 5 inch tube. The edge of RU7 sits flush with the top of the tube and the holes in it are for clearance of the bolts, I'd put some spare M10 bolts in the tapped holes to stop any weld spatter going in and causing problems later.
Old 10th November 2009, 09:25 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, my calipers are set at 45degrees rearward, there are previous posts about this.
Ray
Old 10th November 2009, 09:29 AM
Would that be at 45deg up at 10:30 or 45deg down at 7:30?
Old 10th November 2009, 09:47 AM
RAYLEE29's Avatar
up at 1.30 Passenger side 10.30 driverside or 45 degrees rearward from top 12 o clock
Ray
Old 10th November 2009, 09:48 AM
I would imagine that it is 45% Whatever time of day you make them
I'll get my coat
Old 10th November 2009, 03:27 PM
RAYLEE29's Avatar
Chuckle
