Old 11th May 2010, 12:16 PM
CaptainCrash1971's Avatar
CaptainCrash1971 CaptainCrash1971 is offline
Default Pedal box help.
While in the garage rummaging through the boxes of stuff that came with my chassis I found some odd pieces of steel. After getting my nose stuck into the book, I realised I had a complete pedal box kit, probably from 3ge. This will hopefully save me a few quid, but when I found the donor car's master cylinder it is far to big for the hole in the pedal box back plate. The question is, do I fettle the hole and make it bigger to take the master cylinder, or just buy a new master cylinder?
Is there any difference in the different size cylinders?
Alan
Old 11th May 2010, 12:20 PM
davidimurray's Avatar
I had the same problem. If found both the the big hole and bolt holes were wrong. I think there are different size cylinders depending on exactly which sierra you had. I popped mine on my mill and bored the hole out. You could equally get a file and open it out.
Old 11th May 2010, 01:13 PM
Cheers David
I thought it would be as simple as that, but wasn't sure. The hole is quite a bit out, so will probably have to mark out the hole and drill little holes all round on my pillar drill and file it down, wish I had the use of a milling machine, oh yeah, and the skill to use one
I reckon I must be the most unskilled person on here, can't weld, can't use a mill or laithe, it's going to be interesting when I eventually get round to starting.
Old 11th May 2010, 09:07 PM
DStanley1809's Avatar
DStanley1809 DStanley1809 is offline
CaptainCrash1971, you clearly haven't met me then! I've never welded a thing in my life - I struggled with soldering the last time I tried
I'm just looking forward to the challenge of learning all the new skills
Old 11th May 2010, 09:30 PM
SeriesLandy's Avatar
I found this out too, I tacked a piece of angle iron across the hole, and made it larger with a hole saw.
Old 11th May 2010, 09:38 PM
You're a friggin genius that man, never thought of that.
Old 11th May 2010, 10:45 PM
As Individuals we may not be too bright .... As a group, We Rock
Top tip SL
I probably would have thought of that on the last stroke of 3 hours with a file
Old 12th May 2010, 08:10 AM
dogwood's Avatar
dogwood dogwood is offline
You are soooo right Ronnie, we ROCK...
Brill idea Steve, Now filed in my brill ideas box.
David.
