![]() does the saturn sportscars flat pack haynes chassis kit include the rear top suspension mount/roll bar mount section?? part cp6 i think
![]() also does it include the steering wheel/column support? thanks ![]() |
![]() This is a question for spud but I believe they do come with all the chassis plates
Hope this helps If you need to know quick why not give spud a ring and have a chat with him he is a very helpful bloke |
![]() Do you mean the chassis kit to accept the Sierra or the MX5 donor?
Saturn has a very good package available for the MX5 chassis which includes the full flat pack chassis kit & all the "CP" plates & the "EM" plates for £295. When you say the steering column support ....do you mean SW1 SW2 & SW3? if so, then yes they come supplied in the kit, along with a fully welded front frame which saves the need to make a jig to weld it together. If you are looking to use the Sierra as your donor then the flat pack kit is available for this too, give Spud a call if you need to clarify what you need & I,m sure he,ll help . cheers andy |
![]() thanks guys and its the sierra version but im gonna be using a new 2.0 zetec and gearbox
