Old 11th July 2013, 02:16 PM
Default Flywheel bolts
Hi,
In the Ford Sierra repair manual, they say that if the flywheel bolts are removed, they should be changed to new ones. I just removed the once, and now, I've bolted them back in place with Loctite Thread Locker Blue at the right tightening torque. Do I really have to put new ones? what are the risks?
Thanks.
Old 13th July 2013, 09:52 PM
i know zetec ones you must replace but no idea with others
some makers say you shoud
what engine?
Old 13th July 2013, 10:19 PM
Thanks for the reply.
My engine is 2.0i DOHC.
Old 14th July 2013, 02:48 PM
The Haynes book said the same for the Pinto engine. I haven't heard many bad stories about flywheel bolts suddenly failing but did not want to take the chance so bought a set of new ARP flywheel bolts.
Old 17th July 2013, 05:58 AM
snapper snapper is offline
As Chris said, for £14 you can buy ARP as let's be honest your going to rev the nuts off it when your on the road
Old 17th July 2013, 08:03 AM
Thank you fro the replies
Yes, you are right, for the price, why bothering ? But it is always a mess to find these kinds of "special" items here for me, so if I could have avoid such researches, I would.
And I guess if I go directly to Ford, it will be £14... for 1 bolt
But I will definitely find them and put new ones, saving on this is not worth the risk.
Thanks again.
