Old 29th July 2013, 08:30 AM
Josh's Avatar
Josh Josh is offline
Default Flexible Brake Pipes
Hello, I'm ready to get my brake pipes fitted and have already stumbled at the first hurdle. The book just says to 'fit the flexible brake pipes'. I didn't start with a donor car and have sourced donor parts from all over the place so the book isn't being very helpful here!
Do I just need to buy a standard set of Sierra flexi brake pipes, or is there another kit that would work, or do I need to get custom pipes made up?
Thanks, Josh
Old 29th July 2013, 11:13 PM
Hi Josh,
The OEM "rubber" brake lines from the Sierra will be too short, I'm 99% sure of that.
Almost everybody fits "racing" flexi brake lines which are made from stainless steel braided Teflon hose. They look much nicer on the Roadster than the OEM ones. They are thinner and lighter. They are also much more resistant to pressure thanks to the stainless steel braid, and don't swell under heavy braking as the OEM "rubber" ones have tendency to do. So definitely recommended for sport/fast road driving.
I supply these kind of brake lines, please check my website (address in my signature) if you are interested and send me PM if you need more info or to order.
My brake lines come with 100% stainless steel fittings, and ss lock nuts for the bulkhead fittings. They are fabricated on order, so 100% custom. 26 colours of PVC cover on the hose are available, so you can make them match perfectly with the colour of your car, but you can also choose to keep the natural colour of the stainless steel braid (clear PVC cover), that is the choice I've made.
I've already supplied a big dozen of kit car builders, most of them being Haynes roadster builders from this forum, and they looked quite happy with the product
If I can be of any help, do not hesitate to contact me.
Cheers.
Old 30th July 2013, 12:13 AM
Hi Josh ....I have no doubt that you will have seen my build thread and I can hand on heart say that this is the bloke you need to use for brake lines, and very competitive prices ....give him a go bud and you will not be dissapointed.
Old 30th July 2013, 01:09 AM
Or you can buy the braided hose and Euroquip fittings on Rally Design or other places and build your own. The cost is about 60 pounds, plus shipping. But then you don't get the nice things such as the vynil top cover and the angled fitting for the rear hose to go around the upright. And Euroquip fittings are galvanised, not stainless.
Old 30th July 2013, 09:03 AM
I'm sure I've read that self build brake lines are no good for IVA.
Old 30th July 2013, 10:34 AM
jps jps is offline
Sylvians brake lines do look seriously good - and his website is excellent - the diagrams etc are a great resource for thinking about routing piping, etc...
