Old 1st January 2014, 06:54 PM
sparkybagnall sparkybagnall is offline
Default selling up
hi after much consideration i'm selling my project i do not currently have the time to complete i have the following
fully welded chassis
brake hose brackets, steering rack mount fire wall only thing missing is seat mounts and head lamp brackets no rust just needs grease and grim cleaning off
full set of wishbones from 3ge
full set of poly bushes and steel crush tubes
rear uprights drum set up
front hubs with mushroom adaptors
full ball joint set (maxi, transit, escort rack ends)
escort mk2 steering rack + ali clamps
5mm thick ali sheet for floor
mx5 engine mounts supplied by talon
bent diff mounts from owen eng
full set of bolts for suspension
hope some one can finish this project and make a great car the chassis is very weld made by a chap that used to work for bentley so perfect this will make a great project for some one
looking for offers around £850 for the lot and i could deliver for fuel within 100 miles of derby
i would consider selling parts separately
