Ok I don't know if this is the right section to be asking this if not please forgive.
Right, I'm looking to fit my roll-bar to the car I have had the bar made by a local company, but we won't go into that it's a sore subject, my question relates to the support bars going backward. Could I fit a couple of suspension brackets to a plate welded in to the two box section uprights, the ones that are vertical between the rear hoops, and then fit a bolt through the tube. The brackets would be welded to the plate. I seem to remember that they would not allow the original design saying that it needed two bolts to anchor the rear stays. Does this make sense or does it seem like I am talking a load of twaddle. Arfon ![]() |
Sounds like how I did mine?
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
+1 for stots idea afraid I shamelessly copied it but I did move them outboard of D12
Gary |
That is great, but does it have to have a collar through the tube or can you just put a bolt through it. I have used 40mm tube so there is very little clearence between the tube and the inside of the bracket
Arfon ![]() |
A crush tube?
Definitely. |
definitely a crush tube not just a bolt
Gary |
