Old 26th February 2017, 01:49 PM
Wain Wain is offline
Default Headlamp beam pattern incorrect.
I have attached an image of my current light beam pattern. Failed the IVA because of the blur around the flick up.
MX5 loom, headlamps from CBS, replaced the bulbs. Any ideas what could be causing the blur?
File Type: jpg tmp_19207-20170226_124827-1024x5761068985968.jpg (67.6 KB, 20 views)
One day it will be on the road......
Old 26th February 2017, 05:17 PM
garyt garyt is offline
Mm I'm not sure but are both light images the same n/ and o/s ? On projected image there are only 3 variables ,1 lenses or 2 bulbs or 3 reflectors
I ware the light units a pair ? As if there is a blur I would suspect the lens
What size lights I have a spare 7" lens unit if required
Old 26th February 2017, 06:16 PM
I have pretty much ripped the wiring appart and checked all earths to rule that out, changed the bulbs and now thinking lens as well.
Yes they are 7", if they will fit i will give them a try. Shall i pm you my address?
Old 26th February 2017, 07:16 PM
Yes pm me your address I have one spare unit that you are welcome to at least if that sorts the issue then your halfway there, will get it posted tommorow all being well
Old 26th February 2017, 08:39 PM
Message received will get it posted tommorow oh and I have ignored the other part of the message
Old 26th February 2017, 09:21 PM
Thank you, appreciated. I will let you know what difference it makes to the pattern once it is fitted.
