Old 8th February 2010, 11:35 AM
Default Fuel inlet info sought
Hi all,
I,m looking at connecting up the installed fuel line to my carb ( standard carb setup) on my CVH,
my question is this.........
Do i NEED to run a return fuel line back to the tank from the fuel vapour seperator or can i ditch the seperator ( its in the engine bay) , or keep it in place & just run a short return line from the seperator & "T" it into the fuel line that feeds the fuel pump (which is attached to the top of then engine)?
your thoughts/suggestions are welcomed.
The reason i,m asking is that i intend to run bike carbs so won,t need a return back to the tank, so i,m being both lazy & forward thinking
Old 8th February 2010, 12:25 PM
I would put the return in, i think the vapour preasure trap is there to prevent the carb being over preasured which may lead to the car running rich.
And anyway. when yo step up from the bike carbs to the throttle body injection on megasquirt your going to need the return
Old 8th February 2010, 12:41 PM
gus's Avatar
gus gus is offline
Hi Andy,
I had the same discussion with AdrianH. We both threw the vapour serperator in the bin. Mine runs fine without it.
Like you said I have looked at running bike carbs in the future, and by using a bike interrupter fuel pump you don't need the return to the tank.
I wouldn't both with it in my opinion.
Gus
Old 8th February 2010, 12:49 PM
Originally Posted by gus View Post
Hi Andy,
Gus
cheers "Gus",
that was my thoughts, but just wanted someones opinion on whether i,m thinking right
so , are you saying to just run the fuel line straight into the fuel pump & ditch the seperator all together?
thanks for your help
Twin Turbo.....
That also was on my mind but then thought that the carb wouldn,t get under pressure as any surplus fuel vapour would still be in the fuel seperator but fed straight back into the fuel line going into the fuel pump, instead of travelling all the way back to the tank, if that makes sense. tho i might be wrong
Old 8th February 2010, 12:58 PM
gus's Avatar
gus gus is offline
Andy,
I ran the pipe from the tank through a filter & then onto the pump. From the pump straight onto the carb.
I think this is what most people will say. I think I have seen this come up on LCB builders before, and they all say to bin it.
Gus
Old 8th February 2010, 01:25 PM
Andy,
Gus
cheers Gus,
just what i wanted to hear (read)
thanks for your help.
