pipe/tube beading tool diy
somebody on here was asking about a tube/pipe beading tool
the other day.. a guy(O2GF74) has posted his home made beading tool very diy but the idea can be used for bigger/smaller pipes etc its very simple and also quite clever really a simple and effective solution good man sharing it with everybody hope its of interest to somebody cheers les g PS: its under the heading .....can you see what it is yet |
Not a bad idea is that Les
I was thinking of turning up a male & female set of rollers ( Not unlike a set of tube cutters ) in the lathe. Set them into a pair of sturdy fingers, add an adjustable clamping/pressure screw & Bob's your uncle I had a look at some of the Pro ones .... Friggin hell, have you seen the price of em
I am not a complete idiot...........Some of the parts are missing !! Ronnie www.roadster-builders.co.uk |
hi Ronnie
yes thats a good idea as well. i also thought that if you made one similar to Matey,s with a good chunky bottom bit to hold in the vice a fixed stop to hold the pipe against and the top bit heavy enough to hit/tap/beat with a hammer......... you could rotate the pipe one handed and and tap away with the hammer it could be a nifty solution if you get what i mean cheers les g |
Hey Les, that's not a bad idea mate
I suppose you could fabricate a hinged anvil & dolly to clamp in the vice + a little sping to stop it bouncing ..... Probably makes no sense but you have given me a cool idea & probably persactly what you are thinking I feel another one of my dodgy " Windows Paint " sketches coming up
yes thats exactly what i mean i dont do sketches unless they are on the back of an/oil filter box lol deffo not on a computer cheers les g |
Sand fill the tube to be bent and it won't crush....gentle heat will make it easier
