Old 16th November 2010, 09:11 PM
Andy_B Andy_B is offline
Default my chassis pics
Evening all....if i have done this correctly there should be some images of my tacked together chassis...The chassis was supplied by Saturn and i cant sing their praises loud enough ...the technical backup is superb ...the knowledge is phenominal ...if i had this kind of service in my day to day job my hair would still be the same colour and not falling out quicker than i can get to the barbers !!
Anyways the chassis is nearly formed a few wee bits need sorted around the tranny tunnel and i need to sort out that rear cage ...the bottom rails are a few mm out ...measured corner to corner every where today with the lazer tape borrowed on a long term basis from work !!! and i am at the most 2.25mm out....
PS this is the Nocost version of AVS hahah b'tard watermark !!
Old 17th November 2010, 05:42 AM
Wynand's Avatar
Wynand Wynand is offline
Looks great. Nice to see a person using a centre line to work from
Wynand
http://5psi.net
Old 17th November 2010, 08:28 AM
What gearbox are you using? If you want to fit a type9 pedal box you have one of the U's around the bell housing in the wrong place.
Old 17th November 2010, 08:34 AM
gaz05 gaz05 is offline
I wonder how many of us have made that mistake!
Total cost so far
Materials £3,150
Tools £855
Old 17th November 2010, 08:38 AM
Me more than once, you would have thought after building 20+ chassis I would remember where it goes by now.
Old 17th November 2010, 09:36 AM
Thanks i am using the MT75 gearbox and 2.0 DOHC engine..
