Doing up new ball joints
Evening all...been doing some assembly today of the front end...have had a bit of bother with some of the ball joints ...some of the nylocks have done up nice and tight ...some have started spinning the ball just before the nyloc is on the thread...is there a trick of the trade lo lock the joint in place so it can be done up..??
The way I was taught with the Army was to give it a smack with the hammer to try and get the tapered joint more solid.
Or to jack the joint up to force the tapered joint again.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting |
Some have a hex key slot at the end to hold it in place
AJ'S Build |
Or wrap a ratchet tie down strap around the upper and lower wishbone to pull them together, hopefully then the taper will seat and stop it spinning while you tighten it
It'll be grease/oil contamination that's causing it.
Rub the tapers clean with a thinners rag being careful not to get it on the rubber of the ball joint. |
As Steve said, make sure both surfaces of the taper are squeaky clean.
If you have a stubborn one that does not have a hex in the end, I find a little light pressure from a lever will help ( Protecting paintwork etc with a rag if need be ) Turn the nut slowly & it should not spin the ball joint. If you are just test fitting the ball joints, place a few washers under the nyloc nut. This will prevent damaging the nyloc & if not over tightened, will allow easier removal of the joint again prior to final assembly
I am not a complete idiot...........Some of the parts are missing !! Ronnie www.roadster-builders.co.uk |
