Seamless tube
Ok I am about to make some bones and and I would love to know why was it decided that 19mm seamless was the way to go for top wishbones? Why not 18mm or 20mm?
From what I am led to believe, in industry, 18mm and 20mm are by far the more frequently used tubes and hence far more easily obtained by the likes of me who is building in true locost style and trying to spend nothing whatsoever I am just a little curious to know where the 19mm came from particularaly as i have about 5m of 18mm hydraulic seamless with a 2.65 wall (I think) which was very kindly donated to the cause lying in my workshop. So what do you guys think; should I throw caution to the wind and use the 18mm tube? |
J p.s. I don't know why the unhappy face is in this reply but I can't get rid of it!!!! Last edited by Jimmyd : 23rd March 2011 at 11:15 AM. |
Maybe it's because 19mm is the closest to 3/4 inch? If he had 3/4 inch to hand, used that then converted it to metric it would have come out at 19mm.
Wishbones have traditionaly made from 1" & 3/4" tube, probably going way back to the original Lotus 7 As Enoch said, this equates to 25mm & 19mm in metric. If memory serves me right, the original lo-cost had wishbones made from 1.6mm wall thickness tube !!?? Personaly, I would use the 18mm tube that you have to hand, the wall is certianly thick enough.
I am not a complete idiot...........Some of the parts are missing !! Ronnie www.roadster-builders.co.uk |
i used 20mm because it was what i had look at the top wishbones on a caterham they are about 15mm
My Roadster Is Finished NerNer....... Pigs can fly, you just have to carry them onto the plane. My Pictures http://s707.photobucket.com/user/ashgardiner/profile/ |
Most if not all Kit Car firms use 14swg ERW not CDS
You can use 18-20-22-25mm -3/4" 7/8" 1" CDS if you want for the top wishbones or even ERW if your saving money although I would'nt go lower than 2mm wall. I've done a few pairs of top fronts in 25mm tube and they look quite chunky. I would not use hyd. grade CDS though as it's anealed so it can be formed to tight bends.
