Old 18th December 2011, 03:34 PM
brainbug007's Avatar
Default Saturn Side Panels
So I finally got my 10 piece set from Saturn and spent a bit of time trial fitting this afternoon. When it comes to the side panels I'm a bit perplexed after alot of head scratching :S
Two things I'm a bit confused with:
1) on the bottom (or perhaps top) of the side panel, one end has a much larger bottom triangle shaped area that comes out at 90 degrees. Does this section to towards the front of the car or the rear?
2) Do the side panels do away with side supports? (ss1 i think without the book handy to check for sure). They're a sort of arch/circle shape that goes from the top rails on the side of the car to the seat back. Problem is I cant see how you can fit the side panel as wont this section get in the way??
Here's a pic of the front end though with things roughly where they need to go, just need to move my bulkhead & scuttle forward about an inch to get a snug fit
Old 18th December 2011, 03:37 PM
not sure about side panel ,but the re your other issue.. is no you do not need the curved bit
Old 18th December 2011, 04:09 PM
The triangular bit is to the front. I made a cardboard template and offered that up before making any expensive mistakes.
As already said the curved sections are not required.......guess your going to be cutting them off
Old 18th December 2011, 04:28 PM
Those templates on ebay are a bargain at a fiver a pair
Bob.
Old 18th December 2011, 05:55 PM
Cool the curved bits are coming off then Has anyone got any good closeup pics of them fitted?
Old 19th December 2011, 09:05 AM
Hi Brian,
I've posted a side panel cutting template previously for the front of the panels around the wishbone area:
http://www.haynes.co.uk/forums/showt...ght=side+panel
Should help a bit.....>AndyH
