Old 12th June 2008, 05:26 PM
Jezzer99 Jezzer99 is offline
Default 1.8 Sierras
Hi all,
Quick question on donor cars - do all 1.8 Sierras have the CVH engine and in turn does that mean they all have type 9 gearboxes?
Thanks,
J
Old 12th June 2008, 07:03 PM
frankie boy's Avatar
HI
There are also 1.8 pinto engines as in the book.
Frank
Old 12th June 2008, 07:10 PM
Originally Posted by frankie boy View Post
HI
Frank
Are the 1.8 pintos any good? And are they usually mated to a type 9? I've got an offer of a car that I might be able to pick and choose what I want and, to be honest, I'm thinking of going Zetec rather than pinto.
Old 12th June 2008, 07:20 PM
Hi
If you are going for the zetec the 1.8 chv would be a better doner. The chv sump can be lowerd to fit the zetec. Im also think the mt75 and the typ 9 box will bolt up. All the rest of the doner as the book.
Frank http://www.flickr.com/photos/15477685@N06/
Old 12th June 2008, 10:51 PM
Chris Gibbs
Given the choice I'd go for the zetec, if you have the money/time to sort out the ignition and fueling.
The pinto's advantage is that it drops in with the standard carb and ignition.
I've got the 1.8 in the Roadster, and a 2.0 in my locost, to be honest I can't feel much difference.
Chris
Old 13th June 2008, 08:48 AM
Thanks Chris. You have the 1.8 Pinto in your Roadster or CVH? Does anyone know of a good place to help me identify the engine types (presumably by engine number?) and gearbox types (presumably this is the position of reverse gear?)
Cheers,
J
