Old 3rd April 2012, 05:54 AM
Default Steering column shaft length
Hello,
For a Sierra based Roadster, does anyone know how long the steering column shaft should be from the top coupling to the steering rack coupling when extended ? Rally Design sells a 380mm steering shaft, and I'm wondering if it will be OK instead of extending the shaft my self as explained in the book.
Thank you.
Sylvain
Old 3rd April 2012, 10:57 AM
Hi Sylvain...I'm fairly sure that distance is a lot longer than 380mm or am I reading your post incorrectly
kev
Old 3rd April 2012, 11:46 AM
Thanks Kev, I think you totally understood the question in spite of my approximate English
Do you or somebody else know where I could purchase the extended steering shaft ?
Thanks.
Sylvain
Old 3rd April 2012, 02:01 PM
Your english is fine mate ....I have never heard of anyone buying a shaft, although some have bought THAT shaft from RD and extended it to fit back up to the steering column joint at the bulkhead.....this is one of the jobs I am due to do and I think the above is the way I will be going, but I'm sure some one will come on here and either say the same or explain how they did it.
kev
Old 3rd April 2012, 03:33 PM
Sylvain, here's mine. http://imgur.com/a/w1QR3
I can put it on and off without unbolting the upper part of the column by sliding up the triangular shaft before connecting the splines at the rack.
My extension is ~54cm long, and the shaft inserts into it by ~6 cm at each side. So the total length of extension needed is ~42 cm.
Old 3rd April 2012, 06:32 PM
Thank you guys, and thanks to Alga for the pictures and specs. I guess I will have to make it myself. I'll check if I can use the donor car shaft when I get it (Sierra) before buying the one from RD.
Kev, could you keep me updated about the way you'll do it ?
Thank you.
Sylvain
