Old 16th April 2012, 12:14 PM
misty misty is offline
Default wiring
Hi All
I would like to run over this with you all to see where i am going wrong
battery+ to large bolt on starter solenoid and from the starter solenoid to alternator, small cable from alternator to ign.
coil+ to dizzy and from dizzy to earth.
alternator to be earthed
run an earth cable from battery to gearbox
Now this is what i have done just wanted to check with you all to see if i am correct.
If i am wrong could you please let me know as i am an idiot so it would have to be idiot proof
many thanks
Old 16th April 2012, 12:59 PM
brainbug007's Avatar
I'm not sure about this for certain, but I think you should have a thick red going from the starter to the battery+, a black/red going from the starter to ignition (it should change to black/blue by the ignition), a red going from the alternator to battery+, and then a thin blue going from the alternator to the instrument cluster.
I'm not sure about the coil/dizzy as my engine doesn't have that setup.
Yes you should have a thick black wire going from the battery- to a gearbox bolt.
Old 16th April 2012, 01:35 PM
SeriesLandy's Avatar
I also had a blue wire going from the alternator to the auto choke.
On the coil, I'm sure the -ve went to earth and the +ve (green wire) went into the esc unit.
Not sure about the dizzy
PS dont take it as gospel, I've slept since then.
Old 16th April 2012, 05:41 PM
er would depend on what engine and ign setup you have
only bit that sounds odd is the coil bit
usualy ign+ goes to coil+ then the cb side would go to the points that got the neg side conection from the dizzy body but meny later engins had eletronic ign to replace the points.
i think the ign + is still to coil +
Old 16th April 2012, 06:26 PM
Agree with BAZ on the coil.
+Ve must be an ignition live feed.
-Ve must be a wire to the correct control module for the engine ( ESC, ESC2, ESC-Hybrid,EEC-IV or TFI )
Old 16th April 2012, 06:51 PM
sorry should have said it is a pinto 2 lt engine, no fancy stuff ie ecu or anything like that hope this helps this engine has points
