Old 22nd January 2017, 05:26 PM
garyout garyout is offline
I think 40mm seems to ring a bell, cheers for info though.
Gary
Old 22nd January 2017, 07:00 PM
SteveH1 SteveH1 is offline
Yea mine is fourty millimetres below i just put the chassis on fourty millimetre blocks and put the engine on the ground it balances nicely on the sump then just moved it around until it looked good. And fits under vmax bodywork
Old 22nd January 2017, 07:58 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Dave did i see that you have put the "book spec" rear tub tubes cause they don't fit under the rear tub
Old 22nd January 2017, 08:07 PM
Dave F's Avatar
Dave F Dave F is offline
I have the ones that where supplied by Phil with the TMXR Flatpack, I'm sure he said they be ok! If needs be I'll have to modify them, it would't be the first thing I've had to modify.
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 13th August 2017, 10:11 PM
Dave F's Avatar
Well, not had loads of time in the garage as it's been silly season at work, now that's over and a couple of week in Egypt for some R&R, I decided it was time to build again. So I basically got the pedal box finished, painted, and assembled, not got it in the car yet, then the fuel system plumbed, tonight I got the spaghetti loom out, made some seriously dodgy tempory earth connections, whacked some fuel in and turned the key and f**k me, it fired up.
Not the best video and when it started it shook the camera as I'd ballenced it on the garage door to get the video but you'll get the general idea.
https://youtu.be/otp5Rb61Sgo
God loves a trier
