Old 15th March 2010, 05:59 PM
layotn20 layotn20 is offline
Default wanted rear hub asap
as above need a xr4x4 rear hub. well i believe its off a xr4x4 anyway. just need the hub and not the carrier. bought front/rear hubs drive shafts and front/rear calipers off rsbreakers on ebay. and the 1 hub as had it, the bearings just drop on and off. the shaft on the hub is really badly scored and he wont send me a replacement. but he had the cheak to try and sell me another1
Old 15th March 2010, 06:51 PM
XR4x4 hubs are identical to all other disk brake rear hubs with the exception of the 4x4 cosworth. The only difference you will find is ABS on some.
Old 15th March 2010, 06:53 PM
Heard a few similar stories regarding them.
Old 15th March 2010, 08:22 PM
anyone got 1 for sale . iv bought all new discs pads etc only thing holding me back is this
Old 15th March 2010, 08:37 PM
change the title as it don't need to be a 4x4 one.
Old 15th March 2010, 08:42 PM
iv been to many local breakers today though and iv seen many different rear hubs for the sierra, so im realy confused if this helps these are the same as what i need but i only need the 1 hub, no carrier etc) http://cgi.ebay.co.uk/FORD-SIERRA-XR...item2eabc4da31
Old 16th March 2010, 09:35 AM
carlknight1982's Avatar
abs is fitted to the rear arm not the hub they should all be the same from all disc brake axles
Old 16th March 2010, 11:52 AM
I will confirm that tonight as i think front ABS hubs are listed with a different FINIS code on fords parts system.
Old 16th March 2010, 05:50 PM
Confirmed Microcat only has 1 rear hub listed for rear disks regardless of model.
