Old 6th August 2018, 09:27 PM
SteveH1 SteveH1 is offline
Finally got the engine back together mostly
Old 7th August 2018, 06:34 AM
Scrubbed up nicely
Old 19th August 2018, 09:56 PM
bentovey bentovey is offline
Just read you entire build, great work!!
I’m just starting mine (mx5 just stripped)
Keep up the good work, and posts
Statistically only one in seven dwarves are happy
Old 18th September 2018, 11:25 AM
So ive got a bit done recently
First i built an spacer for the new rear coolant pipe for the reroute to move it out from the block
Then i filled in the the hole in the side coolant connector
Used a 20 cent to stop the epoxy running into it
Filled with epoxy
The hole was a feed for the interior heater so is not needed
Old 18th September 2018, 11:34 AM
This is the coolant reservoir That i got
It only has this mounting point so i made a bracket to hold the whole thing
I also removed the old mounting points for the heat shield from the manifold and cleaned and painted it
Old 18th September 2018, 11:40 AM
I also started on the pedal box
I also mounted the ecu under the dash
And made a bracket for the accelerator cable
And the engine is back in
Old 18th September 2018, 08:22 PM
Next up was to mount the radiator to the chassis
I was originally going to use a spurious golf rad which was not great looking to be fair then coolex had nice ali rads for a polo for quiet cheap at the national kit car show so i picked one up
I Got two brackets bent up for it to mount it to the chassis
Clamped in place to check everything lines up
Checking the fit of the nose cone
I decided to add two new pieces to the chassis rather than drill through the existing chassis
Old 18th September 2018, 09:37 PM
Then i started on the piping for the cooling system which i picked some of it up at the kit car show
And some of the rest of the parts came from aliexpress
I picked up the wrong size pipe so i need to get some more 32mm id piping
Then i started on the wiring which is a whole other can of worms
Old 19th September 2018, 02:32 AM
RandyBMC RandyBMC is offline
Wiring is one of my next big tasks. Are you going to shorten/remove unneeded pieces on the stock harness?
Old 19th September 2018, 08:44 AM
I have most of the unnecessary wiring stripped out now.
The car i stripped had almost every extra electronic thing available so i reckon i have about half of the origional wiring removed
I just needs lots of organising and adjusting.
If your gonna strip the unnecessary wiring make sure you have a good wiring diagram
