Old 11th October 2018, 06:45 PM
bentovey bentovey is offline
Default Talon front upper wishbones
Hi I have a set of talon wishbones to fit a TMXR chassis,
I’m using the mx5 front uprights so I’ll need a pair of ball joints to connect them.
The problems I’m having are,
1- which ball joints do I need?
2- the wishbones are threaded differently, one is M16 and the other is M14.
Is there a reason for this or am I missing something?
Statistically only one in seven dwarves are happy
Old 11th October 2018, 09:44 PM
Numplumb Numplumb is offline
Hi on my Talon wishbones with mx5 uprights I used mx5 bottom ball joints
And BMW 3 series top, mine wasn't a Talon chassis so I don't know if the wishbones are the same.
Regards Mick.
Old 12th October 2018, 06:01 AM
Hi Mick,
Do the series 3 bmw ball joints have odd threads, which year?
Many thanks
Ben
Old 12th October 2018, 06:04 AM
The talon chassis uses ‘book’ wishbone bracket positions.
Did you have to team the uprights to fit the bmw ball joints?
Ben
Old 12th October 2018, 09:21 AM
Hi no my chassis is the book chassis with the Saturn alterations, it doesn't need any reaming it's the track rod end that you use, I don't remember the year but I think the 3, 5 series are the same but you will have to check.
Regards Mick.
Old 12th October 2018, 01:19 PM
Thanks Mick
Old 12th October 2018, 04:39 PM
garyout garyout is offline
Hi Ben
I have a tmxr chassis what your need is a pair of bmw 5 series drag link joints I believe the part no is FTR4112 first line. Bottom joints are mx5.
Cheers Gary
Old 13th October 2018, 08:57 AM
Hi Gary, those seem to be the proverbial hens teeth.
Nobody has any, FTR4112 is a track/tie rod end not listed as a drag link
however I did find these in Germany :
https://rover.ebay.com/rover/0/0/0?m... 263691148981
I’ve been told they are the same, or there are Moog ES2047R items but I can only find them in US
The other problem I’m having is I have a wishbone with m16 thread and another with m14 thread. Should I just drill and tap the m14 to m16?
Old 13th October 2018, 09:23 AM
Hi Ben can't you take one of your wishbones to a parts dealer and try a track rod end, I'm sure that is what fits.
Well it definitely was for mine.
Regards Mick.
Old 13th October 2018, 10:08 AM
That’s exactly what I was going to do on monday
