Old 18th April 2009, 10:52 PM
Tilly819 Tilly819 is offline
Default Small UJ for BEC propshaft
Hi all
I have a slight problem, should have asked the guys at MK today but forgot
I need to mod my propshaft to go onto the bike engine sproket adapter which means i need to cut off the type 9 gear box splined bit and replace it with a small 4 bolt UJ saw one on a car at MK today problem is i have no idea what that UJ is from since the sierra was is way to big
I think iv managed to attah a pic of one on a complete prop shaft from westfield iff not here is the linky
http://www.westfield-sportscars.co.u...hFor=&PT_ID=71
anyway its the small UJ at the close end of the pic
CHears
Tilly
Old 19th April 2009, 08:28 PM
fabbyglass
Personally I think you would better having a prop made rather than make one yourself, only needs to be a gnats nadger out of balance to cause an accident...I found out the hard way
Old 19th April 2009, 09:18 PM
les g les g is offline
loads of info on locostbuilders of various propshaft makers etc
cheers les g
