Old 9th October 2011, 06:37 PM
Cool What shocks?
Hi guys,
Ok soon gonna need some shocks for rolling chassis so what type, where from and how much will they cost?
Old 9th October 2011, 07:13 PM
brainbug007's Avatar
Both the protech and gaz shocks are really good. I've got protech personally. I paid about 350 quid for them, defiantly one of the most expensive parts of the build :|
chrisponter chrisponter is offline
It's detailed in the book, in the part section at the front. Coilovers, 13" open 9" closed. You can buy them from companies like gaz or protech, and Saturn sports cars do them too.
Old 9th October 2011, 07:34 PM
shh120m's Avatar
shh120m shh120m is offline
Go for Protech, they are much better made for the price. Service is spot on too, they even answer the phone at 7am! 13 open 9 inch closed 34mm bush
Old 10th October 2011, 08:54 AM
Originally Posted by Johno View Post
Hi guys,
For the Mx-5 chassis John you can go for the same as the book, only thing i would recommend to change is stiffer springs on the rear, 250lb, it gives a stiffer and better feel to the rear of the car.
AndyH
Old 10th October 2011, 06:37 PM
13" open and 9" closed with a one inch extension are expensive and only availble from a few suppliers if you use a shock that is 14" open and 9.5" closed you can used any make coilover type shock as its a std size
i have gaz units (without extension)and the bottom front lower wishbone shock bracket needs a small amount ground off
see this http://www.haynes.co.uk/forums/showthread.php?t=5820
Old 11th October 2011, 07:41 PM
I found some shocks in the worshop off a jag back end xj12/6 they to are 13" open and 9" closed. Coil overs but non adjustable. Before i get shouted down i was thinking that they might be an ok stop gap for those not ready to pay shed loads for a spax/gaz/protec coil over set up. Jaguar supply plastic shims to tailor the ride height and they are cheap second hand, springs are easily avaiable in different rates.
http://www.ebay.co.uk/itm/4-X-JAGUAR...item1c1f45b429
Old 12th October 2011, 12:10 PM
MikeB MikeB is offline
I guess if the open closed lengths are a match they will fit and get you iva'd
But as a jag would weigh a lot more than a 7 I would guess the damper rates would be very high, giving a harsh skittish ride.
I'm sure someone could revalve them?
So for four new ones with springs you'd be up at £200 against £300-350 for a decent set. If the jag ones are the way forward to get you running I'd probably get some cheap second hand ones and put the £200 towards some proper coilovers when funds allow.
I'm sure its been said before, these car are all about the handling, but each ones tailored for each owner in terms of price, perforamce, spec so make it your own, as long as your happy with it thats the important thing
Old 14th October 2011, 08:56 PM
Hi guys,
Thanks for the info, been some interesting comments. Hopefully this weekend will get a chance to look around for some on the net, so if anybody has a site to check out please let me know.
Can't wait to get a rolling chassis on the go. Tacked my suspension mounts on today and its starting to resemble a car......
Old 14th October 2011, 09:26 PM
Must say it was great once I got mine rolling. Did really make it look like a car My avatar is still my 1st proper pic of the car once I rolled it out the garage for the 1st time. I would seriously consider saturn though for your shocks & springs. I got mine on a group by and there wasn't really a big difference in the price, plus you'll get really good service as well
