Old 21st April 2016, 09:41 PM
RichardH RichardH is offline
Old 22nd April 2016, 08:00 AM
Rosco Rosco is offline
are you using those adjuster on all the wishbones? its just you might find the pitch Isnt fine enough when you come to doing your alignment, I'm using fine thread rose joints (1/2" unf i belive) and its amazing how much half a turn affects things
My Build Thread
Old 22nd April 2016, 08:26 AM
SteveH1 SteveH1 is offline
Thanks but bit late for that now have bought the threaded tubes for them already. Sure it will give me something to do remaking them in the future when ever if finish 😃
Old 22nd April 2016, 08:28 AM
Originally Posted by RichardH View Post
Thanks had intended to wait till i had seats and all steering until i did it
Old 26th April 2016, 08:58 PM
Started on my wishbones
I was dreading these a bit but the first one worked out fine
Untitled by stephen harborne, on Flickr
The two bush tubes and the m16 x 1.5 threaded tube for the ball joint clamped in place
The first arm tacked in place
one side welded
Other side welded
Cleaned up a bit
Only seven more to do
Old 26th April 2016, 10:45 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Looking good following your build with interest
Old 27th April 2016, 08:33 AM
garyt garyt is offline
good work there, I think its all the prep that kinda makes it a though , but once you get going its fine
Look forward to the next 7 pics
Old 6th May 2016, 06:37 PM
Wishbones are easy and fun, I don't get why people are making a fuss out of them. I found a ditch, and the front wishbone has buckled in the middle of the tube. My crappy amateur welds held fine. Getting the plate lasered and bent took more time than making the replacement wishbone. I had some spare bush tubes and a suspension bracket. I didn't make a full jig, just a 25x25 tube tacked onto a 3 mm sheet, with the bush tubes clamped onto it. The wishbone plate just sat on 10 mm spacers (M12 nuts probably) above the centreline marked on the jig plate.
http://locost.lt/download/file.php?id=1012&mode=view
http://locost.lt/download/file.php?id=1015&mode=view
Old 31st July 2016, 10:47 AM
Ok so its been a while but i have been tipping away
Rear upper wishbone
