#151
![]() Hi Johno, glad you like it. Thought people would hate it. Just quickly though before I get to the computer tonight. Does the speedo cable have to go down the tunnel can't it come into the footwell and then go back out, through the floor in your case and under the car. Was messing around with the dash when I read your post. And thought I'd have a play with the speedo cable. Hadn't really give it much thought before, thought it would be the last thing to give me a problem.
![]() Edit forgot to say a small panel could cover the offending cable! |
#152
![]() Quote:
![]() Quote:
I don't know how much I removed but my engine is probably a little further forwards than yours to clear the standard pedal box. Quote:
Cheers Johno, I like yours too but it hurts my eyes to look at your thread. ![]() |
#153
![]() Hi Chris,
Yeah sorry about my photo's, paint schemes a bit loud to say the least... ![]() No reason why people shouldn't like your build as you've got some really good ideas there. In hindsight I wish I spent a bit more time up front sorting stuff out instead of just ploughing in like I have... ![]() It really pays to look at what others have done and have a choice of what you can do with the build. Regarding the Westfield builds and their problem with the mechanical drive for the speedo I've found this... Those of you who used a NA (Mk1) donor, will have found that the speedo cable makes a very sharp bend at the transmission. Every single car that I know of ended up with a broken cable because of this. The only solution is to make a hole in the body to feed the cable through or use the NB (Mk2) cluster with its electrical drive gear (it’s a direct swap against the mechanical drive gear). However, there is a much easier solution. The mazda gearbox has a metric M22-1.5 thread as do old 80′s and 90′s Toyota’s. Most (all?) RWD Toyota’s used a 90° angled drive to prevent this problem. The part is a straight fit for the Mazda transmission! The original Toyota P/N is 83770-30070 and it is meanwhile superceeded by P/N 83770-22100. ![]() ![]() Simon phoned up Toyota today and you can still get this part for £73. I know it's expensive but it's a lot cheaper than replacing the cable every 25 miles...LOL Hope this helps..... Johno |
#154
![]() Chris,
How many fuel pumps are you planning to use on your car. Are you going to use on your car. Are you just using the one from insie the tank or will you add an extra one? Thanks David
Click to see my build photos on Flikr http://www.flickr.com/photos/67112582@N03/ Saturn MX5 Based Chassis, Limited Slip Diff & 2.4 Quick Rack. Build cost.... seems to be spending more on tools than car bits at the moment! (they will be handy in the future though). Car iva'd and passed 15/08/2014. Finished weight 572kg. |
#155
![]() Wow £73!!
![]() ![]() It's not your paint scheme Johno it's cos it's so clean!. ![]() I'll be a little bit sad when my cars finished cos I'm enjoying building it so much so I'm taking my time on purpose and faffing about a lot. I've always wanted to build my own car so putting my own ideas in there is more important to me than building a recognisable Haynes Roadster. Hi David, well I was going to run the standard fuel pump but I do have an in tank bosch pump from a Mercedes ML320 which is cable of providing enough fuel for a 3 litre engine. I was only going to use it when I decided to push for more bhp one way or another. Why do you think you need more than one fuel pump? Last edited by CTWV50 : 21st June 2012 at 11:40 PM. |
#156
![]() Just Ordered!
http://www.cbsonline.co.uk/product/7..._Silencer_SIL7 I'm shaking and sweating after spending so much scraped together paypal tokens on that bad boy!! ![]() ![]() |
#157
![]() Quote:
![]() ![]() wowser ....bet that stung |
#158
![]() Well yes it did. I really struggled to hit the "paynow" button! But it's such a crucial thing in my mind. I tried welding bits of exhaust together like the book says and quite frankly it looked awful and made me laugh every time I looked at it, AND, I've had noisy exhausts on cars before and it was just horrible to drive, you have to be 12 years old to enjoy that kind of din!
#159
![]() Quote:
#160
![]() Quote:
Thread Tools | |
Display Modes | |
