Old 22nd February 2010, 09:01 PM
I thought that was a possabilititty
Would be a shame not to use these pipes as they were £20
Old 23rd February 2010, 06:31 PM
I wonder if the headlamp brakeys can be used as pipe outriggers......
Hmmmmmm..
Old 23rd February 2010, 06:43 PM
Hmmmmmm..
in theory, the front flexi pipes are not supposed to touch ANYTHING from the union of the hard pipe to the caliper, even when the steering is put on full lock either way,
so i would say no to any form of outrigger,
just my opinion of course.
Old 23rd February 2010, 07:27 PM
the rigid pipe would run to a bracket on the headlamp arm, and the flexi from there to the caliper. probably fall fowle of the edge protection rules... Could run the pipe in the headlight tubes thoug and make some sort of hidden braket..
Will have to play when the bones are on.
Old 29th March 2011, 01:36 AM
Default Brake hose length
Originally Posted by dogwood View Post
They have to be long enough to reach from the brakes to the solid pipe.
Snigger, titter, gufufle.
Mine are 450mm long.
Be aware that the flexi on the rear needs to be a banjo type.
Or a short length of solid from the drum.
Does anyone have a good photo of the rear brake hose fitted? Either with the banjo fitting or short length of pipe? I need to have hoses made as the ones I ordered never came. Trying to decide which style of fitting is best on the rear with drums.
Old 29th March 2011, 04:00 PM
oops, found one. http://www.facebook.com/album.php?ai...42c523&theater
Thanks David!
