![]() Quote:
I did say already, one wire goes to earth, and the other to the earth side of the brake warning lamm ( Other wire to the warning lamp goes to 12V ignition switched ), so that's why I say the earth side of the lamp. |
![]() Quote:
thanks |
![]() Ah right, connect that to one wire on the gearbox, and connect the other gearbox wire to 12v ignition live.
~ My Build Diary - http://davesroadster.blogspot.com/ *updated 7/6/11* Best bit so far: Getting it running Worst bit so far: Cutting steel for wishbones and engine mounts. Most annoying bit so far: Generator packing up half way through welding. |
![]() You can mount the megajolt in the engine bay but on a 7 the engine bay gets much hotter than a conventional car, the EDIS is known for not liking the heat, and as EDIS and jolt need to be connected with signal shielded cable I found mounting both under the dash/scuttle worked better.
Attaching a laptop for data logging is also easier with the jolt in the car |
Thread Tools | |
Display Modes | |
