Old 7th December 2010, 01:53 PM
JHewitt's Avatar
JHewitt JHewitt is offline
Default oh dear
Originally Posted by gaz05 View Post
I bought the EDS saver pack and it doesn't fit. Spoke to EDS and it would appear these are for Cortina and Capri uprights. The TRE taper is way too small for the taper hole in my diesel Sierra uprights. The drag link doesn't go all the way through the 3GE mushrooms to allow a full nut on. I can't ream them out either because the rubber is already up against the top of the mushroom. It might work if I get the mushrooms turned down a bit more but non access to a lathe was the reason I bought them in the first place.
It never rains but it bloody pours.
Well gaz, on the plus side for me, at least I hadn't bought them yet, as I was saving for some other bits and bobs needed before. Not that that helps you, but you have helped me, so please now have a warm feeling inside.
Joe.
Old 7th December 2010, 02:27 PM
Gaz,
Have you actually tried doing up the nuts on the joints or are you saying they dont fit by just dropping the joints into position? Reason I am saying this is that the rubber boots on the joints will have slid down the machined tapers and you have to do the nuts up to pull the joints into the taper.
I know gus has used the transit drag links with the 3ge mushrooms with no problem, and it seems strange that Saturn would sell TRE's for the roadster that you are saying don't fit.
Old 7th December 2010, 03:04 PM
i have got the rally design rs2000 steering track rod ends on mine they fit the sierra hubs fine.
Old 7th December 2010, 03:16 PM
The EDS kit is the same as we sell only in separates:
1 pair Maxi Ball Joints
1 pair Transit Drag Links - with half nuts
1 pair RS2000 Track Road Ends
Only call them RS2000 TRE since Rally Designs sell them as this and we all get them from the same place just a bit cheaper for bulk buying. Have used these on cars and been selling them for over a year now and they have always been fine and as recommended in the manual. There has been a few threads created to read on the Locost site about the track rod ends available.
For the transit drag link don't forget to put in a secondary locking device through the upright and mushroom adaptor, ie drilled and tapped 6mm hole with a bolt through. The hole in the bottom upright needs to be reamed out to accept the maxi ball joint to show enough thread for the locking nut, careful not to go too far. The track rod end will pull up tight into the taper with the rubber housing moving down the taper to suit.
All the Best....AndyH
Old 7th December 2010, 03:18 PM
The EDS pack might mention locost, westfield etc. But the joints they are selling in the pack are correct. The maxi ball joints & transit links are as specified in the Haynes book. The only difference is the MK2 Escort TRE's instead of sierra. Having seen both types the sierra ones are handed and have an offset joint. The Escort ones are identical left to right.
I have bought the EDS pack and all the joints fitted perfectly.
Old 7th December 2010, 07:00 PM
gaz05 gaz05 is offline
Thanks for the replies but I'm still not happy. the first pic is the TRE with the rubber removed . The liitle ring around the taper is where the taper is cut on to the shaft. It a definite step and this step is inside the taper hole when the TRE is fitted. This means it's not sitting on the taper correctly.
Even when in the taper and remember this is without a nut on, it has very little movement. Again don't forget that there is no boot on.
Similarly the drag link without the boot shows how close it is to the top of the mushroom and why I can't ream out the mushroom any more. Again it has no nut on so will be even closer when done up.
Without the boot on it has little enough movement. With it on it'll have next to none.
Total cost so far
Materials £3,150
Tools £855
Old 7th December 2010, 07:03 PM
It's possible I may be able to use these drag links but it will mean turning down the top to allow more movement and turning out the inside to allow a full nut on the thread. The TREs will not be fitted. I'll have to work something else out. Is it possible with these being from a diesel that they're different?
Total cost so far
Materials £3,150
Tools £855
Old 8th December 2010, 10:04 PM
MikeB MikeB is offline
Think that was the problem I had with my tre the first time round. The taper wasn't right. Maybe its an age thing with theuprights. Sierra tre should be good. Not sure about the drasg links, keep us posted.
Old 9th December 2010, 12:31 AM
Old 9th December 2010, 08:16 PM
