Old 13th February 2011, 10:37 PM
james3004's Avatar
I was going to make mine from alli, but think I might reconsider that now!
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 13th February 2011, 11:39 PM
rapidtornado's Avatar
looking v.nice... Dave hurry and and get it on your beast we are all waiting with baited breath
Great job Andy
Old 13th February 2011, 11:42 PM
Andy
When you get chance would you be able to give us the dimensions at the front of the bonnet to the top rail, just want check the height as I haven't finialised my engine brackets yet and this will determine how much I drop below the rails
Cheers mate
Rapid
Old 14th February 2011, 09:31 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
looking good there Andy. personally i want my bonnet to have no bulge at all but thats just me being awkward
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 14th February 2011, 10:37 AM
Originally Posted by rapidtornado View Post
Andy
Cheers mate
Rapid
Hi Rapid, the dimensions of the scoop are:
90mm from front of bonnet
60mm deep and 220mm wide at front
280mm wide 300mm from front of scoop.
Hope that helps.......Andrew
Old 14th February 2011, 11:29 AM
Andy_B Andy_B is offline
Andy
Cheers mate
Rapid
Any chance i could take a peak at your engine mounts ..am at the same position
Old 14th February 2011, 03:25 PM
Twin's Avatar
Twin Twin is offline
Well, looks like I may have to start saving
Twin
CSF £857.19
Twins Roadster
Old 14th February 2011, 03:47 PM
Enoch Enoch is offline
I have already done some dimension checking with Andy. My sump is about 40mm below the bottom rails. The objects that cause clearance problems with the engine at that height are the cam covers (only at the front for about 120mm) the fuel regulator and the breather pipe at the back of the cam covers. The engine lifting eye at the front also gets in the way. From the measurements Andy gave me there is sufficient clearance for all those bits. I will be trying it out within the next week - 10 days and will report back but it all seems to be ok from what I know so far. I reckon it will look pretty decent too
Hope that helps.
Enoch.
Old 14th February 2011, 06:00 PM
I will get one of those on order over the next few weeks, its should almost contain my v6 engine. Cheers, Totally missed the thread before
Old 14th February 2011, 07:19 PM
David_17's Avatar
David_17 David_17 is offline
Looks nice Andy. Any pics of it with the rest of the body work? Also, will you get chance to do me a white one sometime to collect friday?
*updated 7/6/11*
