Don't be put off by distance. Equinox has a very good delivery company and its top quality bodywork. You won't get better!
http://www.facebook.com/EquinoxProducts http://www.haynes.co.uk/forums/showthread.php?t=13110 - Z20LET into a Roadster http://s775.photobucket.com/user/ben...?sort=6&page=1 |
I'm really pleased with my Equinox bodywork - but collected at the advice of others just in case. I am in Essex - so the distance to AGM was one of the reasons I ruled them out and went with Equinox.
Although, somewhat ironically, AGM does I believe produce GRP for a chap in Essex who builds these: http://www.furorecars.co.uk/ I think if i'd been closer to Barnsley than Kent I would have gone with AGM myself...
http://meandthekitcar.wordpress.com/ |
I bought grp from exinox it is extremely good quality
17.07.10 "Now i know the meaning of life" My Build pics http://www.flickr.com/photos/67605695@N04/ http://www.flickr.com/photos/97412063@N08/ |
use a merc 190E rad it fits with loads of room
Just for reference the Equinox bodykit is about an inch higher than Saturn/NTS so is great for taller engines and obviously normal engines too
When I was looking I prefered the low line look of the AGM kit and I think its a similar height to the Saturn stuff. I did post a dimension sheet at one point not sure where it is though.
The Equinox stuff is higher so as Ben says is good for taller engines. I prefer the lower look but seeing Ben's car completed it looks pretty good to.
Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501 |
#18
Tbh I've mine up along side a Saturn bodywork. Apart from the equinox bodywork looking a million times better ;-) you wouldn't notice the height difference.
#19
I must admit I am using Saturn and equinox bodywork on the same car and while I thought Saturn provided an excellent service which I still stand by the equinox bodywork is much thicker and rigid
I can't speak about AGM although I think I saw them at a show once and I from memory the bodywork looked good
#20
That was my biggest problem with the saturn panels i had. Especially the back panel as it was so thin and flimsy i was worried it was going to crack the gel coat if you lent against it.
| Thread Tools | |
| Display Modes | |
