Old 10th August 2015, 09:11 AM
Rosco Rosco is offline
Then painted a few little bits that couldn't be powder coated
Steering rack because I had to cut a bit off
Got some Teflon grease for my poly bushes
My Build Thread
Old 10th August 2015, 09:14 AM
Wishbones fitted
Few other bits fitted
Today's job was to get the seat panel fitted, my dad gave me a hand as it was quite tight and didn't want to scratch everything
The panel fit really well from the laser cutters and only needed a little trim on the tunnel top, then the top and bottom needed bending
We clamped the bottom Inbetween two bits of box section and the top between timber with a bevel on the back
It folded real nice
We both decided it needed bead rolling to match the rest
My Build Thread
Old 10th August 2015, 09:15 AM
All sealed and riveted
I decided to gob the backside with the sealer to stop any water or dirt getting trapped anywhere, not the neatest but does the job
My Build Thread
Old 18th August 2015, 10:24 PM
Right I'm back on the updates now, I've not got much done really, I've brought a Bridgeport mill so I've been sorting that out over the last few weeks
Back to the car, my dad made me some radiater brackets and a brake fluid bracket
These will all be powder coated then riveted on
My Build Thread
Old 18th August 2015, 10:26 PM
Engines back in to with stronger clutch springs
Gear linkage next, just working out the size of the bell crank to be made
Down arm added to gear lever, this will be shortened once I've decided the holes in the right place
Lastly put some skateboard grip tape on my pedals, also a clue as to what sort of colour scheme I'm going with
My Build Thread
Old 19th August 2015, 06:17 PM
norton norton is offline
Jealousy is flowing freely through my veins!
How did you drill the bottom row of rivet holes in the rear panel without the floor getting in the way?
Old 19th August 2015, 07:55 PM
Haha thanks!
Urm I dunno really, I just angled the drill away a little, it was close but it's quite a slim chuck on my drill
My Build Thread
On the lathe tonight, I made some countersunk washers for my seats to spread the load a little
Everything aluminium will be going for anodising at some point
My Build Thread
Old 19th August 2015, 08:50 PM
Originally Posted by Rosco View Post
Haha thanks!
Ah good, I thought I was over complicating it in my mind.
Old 20th August 2015, 10:06 PM
Bit more done tonight, I made three more washers, a bit smaller this time for my pedal box
Washed my fuel tank out and mounted the fuel pump
Foam padding stuck to chassis
Tank in place
My Build Thread
