#271
I made a windscreen surround tonight.
Came out nice. Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP Build Started Jan 2013 : OTR Aug 2014 : Build Pictures |
#272
Moar info please! What size of channel did you use, how did you choose the height of the glass? And how did you bend the channel so cleanly?
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
#273
Well it just so happens that I was making a fly screen version and took some photos.
I got the channel from a localish company that make the Caterham and Ariel Atom cars but they don't deliver so I had to pick it up. Really hard stuff to find but I'm sure aluminum extrusion stockists can probably get hold of it. Looks like this, has a 9mm channel and the bottom section has a channel for a seal strip. I made a form from 9mm MDF, put the channel on the top edge, clampped some steel plate with packers around the frame and held it in a vice while I slowly bent it round.
#274
If you are slow and sure the bend comes out perfect but one on this one didnt however you can panel beat the annealed channel and file/sand it flat if it does wrinkle slightly as shown in the pics below. Before: After: For the height I used trial and error. I basically had someone hold the MDF in place and sat in the drivers seat and took the view that the top rail being in line with the upstairs windows of the houses opposite me, ~20m away, worked well which was 13" as it turned out. My fly screen is 4" and when sat in the drivers seat I can still see the nose of the car above it.
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP Build Started Jan 2013 : OTR Aug 2014 : Build Pictures Last edited by Stot : 31st August 2013 at 07:54 PM. |
#275
Today I also finished my steering column extension. As well as welding it I cross drilled it and pressed in 4 roll pins.
I welded the roll pins in also. Its not going anywhere. Cheers Stot
#276
Is there a requirement for a screen surround/channel? I have just bought a piece of 6mm polycarbonate and I intend to fix it at sides and bottom leaving the top edge clear.
#277
As long as you can radius it to requirements it should be fine. J15s have an open top on their screen thingys and people have passed with those.
Cheers Stot
#278
Thats OK --I am no longer interested in radii
#279
That's a good point.
Cheers Stot
#280
Another productive day. I got my exhaust downpipe all tacked together.
Got my brake and clutch pedals in place properly whch included turnong up new push rods for them.
Thread Tools | |
Display Modes | |
