Old 26th January 2014, 09:43 AM
thailoz thailoz is offline
Default Back at it again after a delay an work etc .
Well guys I am back at the build again this past week so check out my blog
Old 26th January 2014, 02:45 PM
Hi!
Good to see you're back at your build mate.
Hope you are safe from the events in Bangkok.
No Thailand for me this year (and no diving ) too much work here. Otherwise I would have travelled a bit more to come to meet you and see your car. Perhaps next year?
Good luck
Old 26th January 2014, 06:38 PM
my brother has just spent 3 weeks there (jealous as fook)
Old 26th January 2014, 11:16 PM
Originally Posted by voucht View Post
Hi!
Good luck
I am about 40 km from Bangkok so no problems If you do make it out would be happy to meet you tho its bloody cold here at the mo 18 C
Old 27th January 2014, 02:15 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
#### off lucky git would have given my back teeth for that temp at work on sunday instead i had 2 C heavy rain with wind followed by snow thunder and lightning then only after i had finished work i got sunshine
so to sum up i was cold wet and bloody miserable then blinded on my way home
Old 27th January 2014, 09:27 AM
True but its all relative I moved here to get away from sub 20 weather so for me a drop in 20 degrees is a hell of a lot .
I dont envy you guys and I am gonna have a lot of driving time if i get this thing finished.
Old 28th January 2014, 03:20 PM
That's what you get for living in Smog Central.
Old 17th February 2014, 11:30 PM
Default Donor parts arrived
Ok got my donor parts from a 1978/79 Toyota corolla KE30 2 door coupe for more details check the blog.
Ps hope all you guys in the south west of England have not been affected buy the floods I have seen on the news.
take care all be safe and happy building.
Old 19th March 2014, 08:56 AM
Default holiday time
Well Schools out for about six weeks so I have time to work on the car starting this week. First thing I did this week was to make a small electrolysis tank (2gallon bucket) may have to make a bigger one as it works really well.
I also got all my transmission tunnel tacked in place including making the hand brake lever.
Next is CP11 I have the already laser cut from 2mm steel just need to bend the 25mm X 2 mm strip round them.
After that fit the front diagonals and now I can also fit the seat back diagonals with those dreaded compound angles.
Then weld up all the tacked rear and transmission tunnel.
check out the blog for details and pics
Old 28th March 2014, 10:01 PM
Default Weldathon complete
Well got there in the end welded up all the chassis upto now and given it a coat of red oxide paint as it was going rusty fast.
more details in my blog
