Old 11th March 2014, 12:57 PM
Cropper Cropper is offline
If you want to be accurate, large civil airliners have their wings held together with interference fit "bolts". Smaller aircraft use Rivets & composites use bolts & glue!!
Hope that helps
Old 11th March 2014, 03:12 PM
Cirrus SR 22 is plastic !
I think you mean what holds the wings on,they are still riveted together.
A lot have "Jesus bolts". Jesus is that what holds that on.
Old 12th March 2014, 12:52 PM
I can assure you that large aircraft wings are held together with interference fit bolts, they are hammered in & have nuts put on the reverse side to a set torque. Having worked on the A380 wings I think I can assure you this is correct!
Old 12th March 2014, 01:10 PM
Grob use a method of a spring loaded ball bearing in a tube to stop the wings falling off their de-riggable aircrage. ie sailplanes. It makes the easy to take apart if you end up landing in a field but always at the back of your mind when spinning
Old 14th March 2014, 09:11 PM
Hi,
Thank you very much for the tips and help... and the very good informations about how to make an airplane wing, it will be very useful if my next build is a DIY plane :-D !
So, I managed to fit my ally floor. 4mm aluminium rivets, 1 every 45mm, with a blob of sikaflex on each of them. Sikaflex on all the rails, including the 2 seat transversal rails.
2014-03-14_16-57-32 par Voucht71, sur Flickr
It may have cost me a bit of money, but I'm very glad I bought a rivet air-gun and also (as I'm a very very lazy guy) and air sikaflex pump! Both of them worked a treat, and automatic tools were very welcome after I drilled all these holes ! A shame this air gun does not work with rivnuts!
2014-03-13_10-36-38 par Voucht71, sur Flickr
2014-03-13_11-29-42 par Voucht71, sur Flickr
2014-03-14_18-15-36 par Voucht71, sur Flickr
Tomorrow, I am going to put the chassis the right way around, and start to reassemble everything, starting with the engine and transmission.
Old 29th December 2016, 04:50 PM
jps jps is offline
Originally Posted by voucht View Post
Hi,
Thanks to all of you for the replies and very useful informations. I now have a very nice smooth black powder coated chassis, and also received the body kit from Equinox. As it has been said here before, the quality is very good.
So, I think I will go for 3mm rivets for the floor, 50mm spacing, same for the trans side panels and back seat panel. And, I don't look forward to this, but I will fit all the body kit elements with rivnuts, as most of you say that it has to be easily removable. As well as the top gearbox and propshaft covers.
Question: for the floor, should I use steel rivets (aluminium will be too weak?)
I'm sure I will have further questions when I start
Thank you very much.
Sylvain, i'm just about to fix my floor, internal panels and bodywork (also Equinox).
I'm inclined to do similar to you, how many rivnuts did you use for the side panels. And did you drill out your 3mm floor (I have 3mm alu for the floor too) to fit the rivnuts flush with the floor panel? I had a look at your blog but my French is not good enough!!!
Old 29th December 2016, 06:04 PM
I understand ! But if you want, there is actuelly a "translate" menu on my blog (right column, right under the blog archive list), and you can chose your language. It is translated by google, so it is not very good, but I guess you can catch the main sense.
Anyway, here are my answers to your questions:
Floor : I actually used rivets and not rivnuts for the floor, because I can't see why I would need to remove it, as I kept the transmission tunnel open, so I have access to the propshaft from underneath.
So I used 4mm rivets every 50mm along each edge.
I also sealed/glued with Sikaflex.
Side panels : all the bodywork I wanted removable. So I used M5 rivnuts, countersunk head.
Top side :
3 under the hood (the one in the very front is also the nose cone fitting point)
2 under the scuttle
2 between the scuttle and the rear arch
None on the arch, but the rear part of the side panel is attached to the chassis with the rear wheel arches.
So it is 7 fitting points + 2 or 3 with the rear wheel arches
Underside :
5 on the front part (in front of the angle)
2 on the rear part (behind the angle)
So it is 7 as well
So 14 rivnuts per side panel.
Hope that help. Do not hesitate to ask if you need
Good luck!
Old 30th December 2016, 08:38 AM
I just realized that I might have misunderstood your question.
You were asking about the rivnuts to fit the side panels through the ally floor. Sorry
Yes, I drilled out the ally floor and used countersunk rivnuts, so they are flush with the floor. Rivnuts have to cope with 5mm thickness (2mm tube + 3mm floor). Mine were OK for that, I tried on a scrap tube and 3mm ally piece.
The link to my blog about that is:
http://vouchtroadster.blogspot.fr/20...panels-09.html
(I moved the "Translate" button on top of the side bar so it is easier to find.)
There are 4 rivnuts fitted through the floor (+ 3 directly on the tube, at the front of the chassis)
Also, these countersunk rivnuts I used to fit my side panels are M6 (9mm hole) and not M5 (7mm hole) as I said yesterday.
I hope I have now answered your question
Old 30th December 2016, 04:48 PM
jps jps is offline
Merci beaucoup for taking the time with a comprehensive answer, much appreciated! I'll take a much closer look through your blog now, the photo's you've got on there are very helpful. Although I am hoping that I do not have the mysterious gaps in bodywork I suspect I may have similar challeneges ahead, as my bodywork has been waiting to be fitted for nearly 3 years now and may have adopted some new shapes...!
