Old 12th August 2010, 10:24 PM
temperature one should have a solid probe, preasure should have a small hole.
thats what I have, the temp one is like a small bullet, the pressure sender is a screw in thread with a tiny hole in the end, on the outside of the sandwich plate the pressure sender has a large body (size of the actual gauge) with the electrical screw on connector on it.
I,ll check the wiring from each sender tomorrow, if they are wired correctly then maybe its what "Mark" has suggested.
One of my winter mods will be a full new dash with these gauges & a bright 6 warning light setup & rev counter & speedo
Old 13th August 2010, 04:18 PM
Thumbs up all working now
Thanks for your help guys,
I had connected everything correctly
The problem was that the sandwich plate wasn,t earthing to the block/chassis, so I,ve ran an earth from the sandwich plate direct to the chassis & it all now works
Oil temp is showing a reading, tho can,t get it up to full temp as not allowed to drive it yet,
Oil pressure is showing between 25 to 30 at tickover & between 60 to 80 at high revs.
Yet again, this great forum came to the rescue , thanks everyone
Old 13th August 2010, 04:52 PM
David_17's Avatar
David_17 David_17 is offline
Glad you've got it sorted Andy, thought that's what it would be
*updated 7/6/11*
