Old 21st September 2010, 07:09 PM
David_17's Avatar
David_17 David_17 is offline
Here's my idler set up. Incase anyone reading this needs some inspiration. I just used some left over box section bolted to the oringinal engine mounting studs - Much easier than making a bracket that bolts onto the side of the block.
*updated 7/6/11*
