Old 20th December 2015, 08:18 PM
Rosco Rosco is offline
Well me and my dad have had two full days on the car again this weekend, got the side panels finish trimmed, painted the inside black and bonded on with tiger seal
Also got the bonnet trimmed to match the scuttle and the scuttle fixed on with Rivnuts
My Build Thread
Old 20th December 2015, 08:19 PM
Rear tub fitted
Then made a card template for a exhaust heat shield
Then drawn up on the pic, we had to rotate so it would fit on my dads cnc
My Build Thread
Old 20th December 2015, 08:20 PM
Finished product in aluminium, I might still cover this in heat reflective foil, then it will be rivited on I think
My Build Thread
Old 20th December 2015, 08:27 PM
norton norton is offline
Tidiest build by far!
Old 21st December 2015, 01:33 PM
Originally Posted by norton View Post
Ahhhh, I've been searching but not found them. Do you have a link?
I phoned Westfield parts and collected them from a show. They showed me on their model how to attach them etc. they are also pre bent.
Old 1st January 2016, 07:08 PM
Right I've had three full days on the car this Christmas, and hopefully two more still to go,
Santa brought me a gopro
My Build Thread
Space heat foil stuck on the aluminium heat shield and bolted on
Exhaust manifold fitted, and even if I say so myself I couldn't stop smiling after getting this all fitted up
My Build Thread
Old 1st January 2016, 07:09 PM
Next job Dashboard, I've been struggling with this, deciding which way to go, I didn't like the look of the equinox one, I wanted a carbon one but there's not one with an iva edge,
In the end I decided to make one with deboned sheet, easy to work with etc, as for the lower edge I'm using black pvc waste pipe, sounds crude but it's turned out sweet
Template first, I used 2mm coriguated plastic from wickes, was only £4 for an 8x4 sheet and can be easily cut
Fixing holes drilled and rivnuts fitted in scuttle
Rubber grommet and sleeve for steering column
My Build Thread
Old 1st January 2016, 07:10 PM
I was in the zone and forgot to take any pictures, I cut all the switch and dash holes out on my dads cnc
Back of the dash
All fitted up for good hopefully, lower edge pipe trim fitted
Full photo
Battery fitted and passenger footrest, I might block the battery off from the footwell with a bit of dibond
My Build Thread
And a full shot for a change, starting to look like a car
My Build Thread
