Old 27th August 2010, 10:10 PM
gus's Avatar
gus gus is offline
HI
Thanks for all the kind messages .
DAVID 17 i used 40 x 3 flat across the car .Then used CBS seat runners welded to 25 x 25 shs.
Gus
Old 28th August 2010, 09:08 AM
DaddyA's Avatar
DaddyA DaddyA is offline
Hey Gus,
car looks great, good luck with the IVA,
Can I ask what have you done to the top harness mount area (sharp edges etc)
Daz...
Old 28th August 2010, 09:24 PM
gus's Avatar
gus gus is offline
Hi Daz
I used end caps that fit 50 x 50 shs .Cut edges and drilled a hole to match harness. all photos are at work, will post 1 on tuesday.
Gus
Old 29th August 2010, 12:01 PM
davidimurray's Avatar
Quick thought Gus - you still have the washer stalk on the column - is that acceptable as you don't have any wipers?
Old 29th August 2010, 07:00 PM
Yes it is, recent IVA, switch with no wipers, no comment.
Old 31st August 2010, 10:15 AM
gus's Avatar
gus gus is offline
Daz,
Here is that picture I said about.
Gus
Old 31st August 2010, 04:46 PM
DaddyA's Avatar
Cheers Gus,
I'll have a look around
Daz...
