#451
Haha cheers guys, we will see how it goes,
hoping to get the wiring finished this weekend and get her running again ![]() |
#452
Right, had a few weeks off the car due to one thing and the other but had a good day today
Got the springs back on the shocks and the ride height set roughly, it's getting corner weighted when it's finished Everything on the rear tightened up, then got the rear tub fitted, the arches and the boot lid fitted ![]() Well happy with it all to be honist, just need a few more black bolts ![]() Pretty much all the wiring is finished and working now, just got to sort the front side repeaters, hopefully tomorrow's job ![]() |
#453
Sunday's progress
Locating pins finally fitted in the nose cone, I will get another shot when the bonnets next on ![]() Side repeater wire extended, and hole drilled in arches, I just used a drill to twist two wires together, turned out quite neat ![]() Wire tiger sealed to the underside of the arch, it will become clearer once the arches are back on the car I hope! ![]() |
#454
#455
Getting there. I really cant wait to see this one the road.
https://haynes.co.uk/forums/showthre...736#post103736 |
#456
Had a good day today, got loads of bits sorted,
I needed to calibrate my water temp sensor to my digi dash as I used the bike sensor, so I got the engine running and with every 10deg c of water temp I noted down the output voltage of the sensor then, entered the figures into the dash and jobs a goodun! Also plunged the laptop into the power commander, pretty cool, tells you rpm etc, but turned out the rpm on the digi dash was reading double, so sorted that. Then worked out how many pulses per mile the speed sensor will read and sorted that, Next job, the front arches, I got them fitted and wired in, ![]() ![]() ![]() I ran the wires down the wing stay and up the brake pipe, it looks ok, not totally happy with it but it does the job, ![]() Also one of my rear copper brake pipes was leaking, took it off and it looked fine so nipped it up a bit tighter and seems ok now, I've had the pedal wedged all day under pressure to! Oh also I wanted an led to say the hazards are switched on, but a little harder than I thought as it also lit up when the indicators are switched on, but bit of research and I've used a diode, which is like a one way valve, so that's now working to Got a few more bits and bobs to do tomorrow and I think it will be about finished, hoping to take her for a spin next weekend |
#457
yeah that's a good days work as it is all the wee jobs that you think "that won't take long" that add up, great work and you will soon be there.
remember we are not mad just creatively insane |
#458
#459
#460
| Thread Tools | |
| Display Modes | |
