Old 16th May 2011, 12:24 PM
Ricky Ricky is offline
Smile windscreen help ?
Sorry meant to say ill go to some ally stores and see if I can get it
Old 16th May 2011, 12:36 PM
axle's Avatar
axle axle is offline
Remember this part of the screen is a double channel
The top part will take the screen is usually about 9mm wide which will take the glass + rubber.
The bottom is the T- piece.
Good luck
Regards Axle
Old 16th May 2011, 12:40 PM
Default windscreen help ?
Yes I am aware of that do perhaps know the name for this cause I been asking for a name and not been able to get one?
Old 16th May 2011, 01:31 PM
Its Extruded Aluminium Channel (commonly used for shower screens).
Old 16th May 2011, 01:33 PM
Is that the bottom one that has that part for the T piece rubber ?
Old 16th May 2011, 01:54 PM
Both upper and lower although i suspect the lower may be classed as double channel possibly.Glass suppliers usually do this sort of stuff.
Old 16th May 2011, 01:58 PM
Oh ok thanks for that info ill be searching for that
