Old 18th February 2013, 07:36 AM
Originally Posted by minicountryman1961 View Post
when I bought my headlamps, I wish I had bought these with the builtin turn signals. A friend of mine did, and his car is looking much cleaner on the front.http://www.yogisinc.com/index.cfm/pa...od/prd7481.htm
Not sure they would IVA would they? They make you put bike indicators on long stalks to make them visible from various angles, cant see ones inside the headlamp being visible from these angles?
Old 18th February 2013, 09:08 AM
The stalks are only needed to get the indicators within 400mm of the edge of the vehicle.
If they were built into the headlights that wouldn't be a problem as the headlights need to be within 400mm of the side anyway.
I suspect where they would fail IVA is with the headlight beam pattern, as presumably they 'kick' the wrong way with them being from the US.
Still a nice idea though!
Old 18th February 2013, 09:34 AM
Davey fitted some all in one units. Not cheap but very neat venom 5, they have side light head/dip and indicator. I think the fronts only need to be visible from the front, the side indicators deal with vision from other angles.
Old 18th February 2013, 09:18 PM
That's my mirrors fitted - one more thing ticked off the list
Old 27th February 2013, 05:38 PM
Stupid question I suppose but how much fuel pipe did you use? Just ordering some now.
Old 27th February 2013, 09:21 PM
If you mean the copper lines I bought 10 metres, and probably have about a metre and a half left (I must have wasted a fair bit!).
If you mean the rubber pipes, I've no idea!
Old 6th March 2013, 10:39 AM
Thought I'd whip the sewing machine out and have a practice go at the boot cover (the real one won't be red!).
Didn't turn out too bad for my first proper attempt at upholstery, some of the seams are a bit wonky, but I think I'm starting to get the hang of it:
I see you have made a second black cover? Red one looks good, and my car will be red eventually. Do you sell the red one??
Old 6th March 2013, 11:10 AM
Sorry Chris, the red one is no more
I was running low on red vinyl, and chopped the red cover up the other night to make some more interior panels...
Old 9th March 2013, 09:17 PM
Speaking of interior panels, I've spent the last couple of days in front of the sewing machine making some more
Just finished fitting my seats and belts too:
Old 9th March 2013, 09:46 PM
Looks ace? What seats are those? There not your original seats are they??
