Old 1st December 2014, 10:12 PM
That is a very nice piece of work well done.
That little rubber bobbin is intended to be used in compression not in shear as you have used it. As the car bounces and the exhaust vibrates the rubber and steel parts will part company after awhile.
Old 1st December 2014, 10:28 PM
garyt garyt is offline
Love the exhaust mount
Old 2nd December 2014, 08:59 AM
robj robj is offline
Cheers everyone I thing it'll be a theme through the car.
Its ok Talon there's another mount under the silencer that takes most of the weight, with the mount the right way .
Old 2nd December 2014, 08:04 PM
Can you get the column bearing any higher, that should help with the steering wheel height.
Do you find that the gear lever hits the handbrake? I had that problem with my extension.
Old 2nd December 2014, 08:37 PM
There seems to be enough clearance for the gear lever it just seems a bit long might have to cut it down a bit. I can't raise the bearing much it means the column hits the manifold. Bit of a re think on the cards I think.
Old 21st May 2016, 10:37 PM
been a while since I've done an update so I thought show you where I'm at.
I've stripped the chasssis back to get body work done.
Thought I'd take it into work as it'll give me a bit more room. I gave it a sand blast and a repaint while I was at it.
Started by doing the trans tunel and seat back thought It'd give me more room if the floor wasn't in the way.
Then I stuck the floor in.
Thought I'd have a go at the rear panel next.
Old 21st May 2016, 10:42 PM
Then the side panels.
Thought I'd have a go at an alloy scuttle so I bought myself a metal shrinker/stretcher.
Old 21st May 2016, 10:52 PM
Cut the bulk head out more work to do on that though. Next up was the bonnet.
Hopefully I'll get some more done in the week and won't leave it so long for an update.
Old 21st May 2016, 11:21 PM
Good to see you back up and active Rob, your ally body work is outstanding mate, I dont think I have seen anything on here to match it
Old 22nd May 2016, 07:57 AM
great to see your updates and that craftsmanship is outstanding it really is nice to see, will be waiting for the next pictures, ally nose ????
seriously good work
